Spot04016.pngBridle preferences
Command
Path
Bridle Preferences
Spotlight > Rigging
Set the bridle preferences prior to inserting bridles in the drawing. Applying one of the Default Bridle Parameters ensures that all subsequently placed bridles have at least one dimension in common, to facilitate planning and assembly. Specify the default dimensions and parts. Optionally, enable the use of structural members as house rigging points.
The diagram indicates where the parameters are located.
To set the bridle preferences:
Select the command.
The Bridle Preferences dialog box opens.
Parameter
Description
Select the default property that determines how bridles are created
Bridle leg angle
Creates bridles with the specified leg angle
Bridle leg length
Creates bridles with at least one leg of the specified length
Bridle down leg length
Creates bridles with the specified down leg length
Apex height
Creates bridles with the specified apex height
Bridle part
Creates bridles with one leg using only the selected part
General Settings
Min. Bridle Leg Angle
Specify the minimum angle between the bridle leg and the horizontal plane
Max. Bridle Leg Length
Specify the maximum leg length
Use structural member as house rigging point
Enables bridle objects created in Auto Insertion mode to snap to structural members
Default Parts
Default Shackle
Select the default shackle
Default STAC Chain
Select the default STAC Chain
Use shackles instead of STAC chain
Uses shackles instead of STAC Chain in bridle assemblies
STAC chain on top of a leg
Inserts STAC Chain at the top of the bridle leg. If this option is deselected, the STAC Chain is inserted at the bottom of the leg.
Save as default
Saves the current settings in the dialog box as the default for this and future documents. If deselected, the current settings are saved only for the active file.
Specify the default settings for bridle objects.
Managing bridle parts
Inserting bridles
Bridle properties
Adjusting the bridle configuration
Creating structural members
